Answer by sangamesh · Feb 04 at 11:20 AM
Que - What I understand is that you want to fetch the Numbers and convert it into Words automatically using Pentaho, right?
Ans - Not sure if Penatho can convert numbers into words.But you could convert it through mysql stored routines/functions and fetch result into pentaho. To do that, Please follow steps as mentioned below:- Step 1 - Go to Heidisql tool, Select database then right click on that and click on Create new - Stored routine. Then update the values as mentioned below:
a) Under Options:-
Name - number_to_word
Definer - root@localhost
Type - Function (returns as result)
Data access - Contains SQL
Returns - text SQL security - Definer
b) Under Routine body:- Copy and replace below content
BEGIN
-- This function returns the string representation of a number.
-- It's just an example... I'll restrict it to hundreds, but
-- it can be extended easily.
-- The idea is:
-- For each digit you need a position,
-- For each position, you assign a string
declare ans varchar(500);
declare dig1, dig2, dig3, dig4, dig5, dig6 int;
set ans = '';
set dig6 = CAST(RIGHT(CAST(floor(n / 100000) as CHAR(8)), 1) as SIGNED);
set dig5 = CAST(RIGHT(CAST(floor(n / 10000) as CHAR(8)), 1) as SIGNED);
set dig4 = CAST(RIGHT(CAST(floor(n / 1000) as CHAR(8)), 1) as SIGNED);
set dig3 = CAST(RIGHT(CAST(floor(n / 100) as CHAR(8)), 1) as SIGNED);
set dig2 = CAST(RIGHT(CAST(floor(n / 10) as CHAR(8)), 1) as SIGNED);
set dig1 = CAST(RIGHT(floor(n), 1) as SIGNED);
if dig6 > 0 then
case
when dig6=1 then set ans=concat(ans, 'one lakh');
when dig6=2 then set ans=concat(ans, 'two lakh');
when dig6=3 then set ans=concat(ans, 'three lakh');
when dig6=4 then set ans=concat(ans, 'four lakh');
when dig6=5 then set ans=concat(ans, 'five lakh');
when dig6=6 then set ans=concat(ans, 'six lakh');
when dig6=7 then set ans=concat(ans, 'seven lakh');
when dig6=8 then set ans=concat(ans, 'eight lakh');
when dig6=9 then set ans=concat(ans, 'nine lakh');
else set ans = ans;
end case;
end if;
if dig5 = 1 then
case
when (dig5*10 + dig4) = 10 then set ans=concat(ans, ' ten thousand ');
when (dig5*10 + dig4) = 11 then set ans=concat(ans, ' eleven thousand ');
when (dig5*10 + dig4) = 12 then set ans=concat(ans, ' twelve thousand ');
when (dig5*10 + dig4) = 13 then set ans=concat(ans, ' thirteen thousand ');
when (dig5*10 + dig4) = 14 then set ans=concat(ans, ' fourteen thousand ');
when (dig5*10 + dig4) = 15 then set ans=concat(ans, ' fifteen thousand ');
when (dig5*10 + dig4) = 16 then set ans=concat(ans, ' sixteen thousand ');
when (dig5*10 + dig4) = 17 then set ans=concat(ans, ' seventeen thousand ');
when (dig5*10 + dig4) = 18 then set ans=concat(ans, ' eighteen thousand ');
when (dig5*10 + dig4) = 19 then set ans=concat(ans, ' nineteen thousand ');
else set ans=ans;
end case;
else
if dig5 > 0 then
case
when dig5=2 then set ans=concat(ans, ' twenty');
when dig5=3 then set ans=concat(ans, ' thirty');
when dig5=4 then set ans=concat(ans, ' fourty');
when dig5=5 then set ans=concat(ans, ' fifty');
when dig5=6 then set ans=concat(ans, ' sixty');
when dig5=7 then set ans=concat(ans, ' seventy');
when dig5=8 then set ans=concat(ans, ' eighty');
when dig5=9 then set ans=concat(ans, ' ninety');
else set ans=ans;
end case;
end if;
if dig4 > 0 then
case
when dig4=1 then set ans=concat(ans, ' one thousand ');
when dig4=2 then set ans=concat(ans, ' two thousand ');
when dig4=3 then set ans=concat(ans, ' three thousand ');
when dig4=4 then set ans=concat(ans, ' four thousand ');
when dig4=5 then set ans=concat(ans, ' five thousand ');
when dig4=6 then set ans=concat(ans, ' six thousand ');
when dig4=7 then set ans=concat(ans, ' seven thousand ');
when dig4=8 then set ans=concat(ans, ' eight thousand ');
when dig4=9 then set ans=concat(ans, ' nine thousand ');
else set ans=ans;
end case;
end if;
if dig4 = 0 AND (dig5 != 0 || dig6 != 0) then
set ans=concat(ans, ' thousand ');
end if;
end if;
if dig3 > 0 then
case
when dig3=1 then set ans=concat(ans, 'one hundred');
when dig3=2 then set ans=concat(ans, 'two hundred');
when dig3=3 then set ans=concat(ans, 'three hundred');
when dig3=4 then set ans=concat(ans, 'four hundred');
when dig3=5 then set ans=concat(ans, 'five hundred');
when dig3=6 then set ans=concat(ans, 'six hundred');
when dig3=7 then set ans=concat(ans, 'seven hundred');
when dig3=8 then set ans=concat(ans, 'eight hundred');
when dig3=9 then set ans=concat(ans, 'nine hundred');
else set ans = ans;
end case;
end if;
if dig2 = 1 then
case
when (dig2*10 + dig1) = 10 then set ans=concat(ans, ' ten');
when (dig2*10 + dig1) = 11 then set ans=concat(ans, ' eleven');
when (dig2*10 + dig1) = 12 then set ans=concat(ans, ' twelve');
when (dig2*10 + dig1) = 13 then set ans=concat(ans, ' thirteen');
when (dig2*10 + dig1) = 14 then set ans=concat(ans, ' fourteen');
when (dig2*10 + dig1) = 15 then set ans=concat(ans, ' fifteen');
when (dig2*10 + dig1) = 16 then set ans=concat(ans, ' sixteen');
when (dig2*10 + dig1) = 17 then set ans=concat(ans, ' seventeen');
when (dig2*10 + dig1) = 18 then set ans=concat(ans, ' eighteen');
when (dig2*10 + dig1) = 19 then set ans=concat(ans, ' nineteen');
else set ans=ans;
end case;
else
if dig2 > 0 then
case
when dig2=2 then set ans=concat(ans, ' twenty');
when dig2=3 then set ans=concat(ans, ' thirty');
when dig2=4 then set ans=concat(ans, ' fourty');
when dig2=5 then set ans=concat(ans, ' fifty');
when dig2=6 then set ans=concat(ans, ' sixty');
when dig2=7 then set ans=concat(ans, ' seventy');
when dig2=8 then set ans=concat(ans, ' eighty');
when dig2=9 then set ans=concat(ans, ' ninety');
else set ans=ans;
end case;
end if;
if dig1 > 0 then
case
when dig1=1 then set ans=concat(ans, ' one');
when dig1=2 then set ans=concat(ans, ' two');
when dig1=3 then set ans=concat(ans, ' three');
when dig1=4 then set ans=concat(ans, ' four');
when dig1=5 then set ans=concat(ans, ' five');
when dig1=6 then set ans=concat(ans, ' six');
when dig1=7 then set ans=concat(ans, ' seven');
when dig1=8 then set ans=concat(ans, ' eight');
when dig1=9 then set ans=concat(ans, ' nine');
else set ans=ans;
end case;
end if;
end if;
return trim(ans);
END
c)Under Parameter:- Click on Add button and type n
d) Click on Save button.
Step 2 - Test if the value in number converts into word by using select query:-
select number_to_word(round(x.principal_amount)) from m_loan x where x.id=5
Output will show in words for example- fifty thousand.
Step 3- Now you could write your sql query and use that in pentaho designer and generate pentaho report.
Thanks,
Sangamesh.Nadagoudar
Skype - sangamesh.n
